I had the front brake pads change . but the brake failer light comes on then gose off after I hit the brakes
Nov 26, 2014 at 2:57 PM
MHPAUTOS
CERTIFIED EXPERT
Check that the hydraulic system is ok, no leaks and bleed correctly, check that the wear indicator is fitted correctly (if used on your model) this is a small carbon rod inserted into one pad that when earthed turns on a brake warning light.
