The brake pedal on my BA Falcon wagon has gone soft and will push to the floor even after having been pumped up 2 or 3 times. The brakes are still working effectively but the brake pedal will still push to the floor with a steady, even (not hard) pressure. I have had it to a mechanic who has (1) replaced the master cylinder 3 times with a second hand unit and then with a new unit , (2) replaced the ABS unit with another second hand unit, (3) replaced the vacuum brake booster unit with a 2nd hand unit; bled the brake system several times and states that there are definitely no brake fluid leaks and could not detect any air leaks in the system. He states that the brake hoses appear to be in good condition. He has given up and states that he does not know what is causing the brake pedal fade. Perhaps you could suggest some further course of action?
Thanking you,
Des
Thanking you,
Des
Jul 25, 2019 at 12:21 AM
