Brake lights wont light up when pedal is pushed... Ive put new bulbs in checked the brake pedal sensors at the brake pedal checked the voltage as well at the brake pedal sensors. So its not the brake pedal sensor or the bulbs or the fuses or the relays. All trim lights work both turn signals work. The same rear bulbs are trim lights and brake lights on the same bulb... And they are brand new. I started to get underneath with my multi meter and got a little overwhelmed. Checked the wiring underneath and everything looks good. its gotta be something underneath... one of those harnesses or something idk.
Jan 4, 2016 at 9:51 PM
1 - Chassis Frame
2 - Fuel Tank Pressure (FTP) Sensor
3 - Fuel Pump and Sender Assembly
4 - Evaporative Emission (EVAP) Canister Vent Solenoid
5 - X402 (Chassis Harness to Right Rear Lamp Assembly)
6 - J404
7 - X401 (Chassis Harness to Left Rear Lamp Assembly)
8 - X400 (Chassis Harness to License Lamp Harness)
9 - J403
10 - J402
11 - J400
12 - J401
13 - J310
14 - X102 (Body Harness to Chassis Harness)
