Sounds like the car is out of tune or missing and brakes not working right?
2008 VOLVO C70
125,000 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
JIM5763
MEMBER
1 POST
FOLLOW
Bought new hoses and booster. after installation running worse, could it be the wrong booster? Or I installed the hoses on incorrectly?
Sep 7, 2022 at 4:22 AM
CERTIFIED EXPERT
Please remove the check valve from the booster (engine off) you should hear vacuum escape. If not, the booster is bad and allows a vacuum leak. Let me know what you find.
Sep 7, 2022 at 9:56 AM
CERTIFIED EXPERT
Also, it could be you have a clogged exhaust system, here is a guide to help check it out:
