I have issue where: Brake pedal sinks to the floor when pressed.
When car is turned on, when brake pedal depressed a hissing noise comes from the brake booster, as well as rough idle. (I have all the symptoms of failed brake booster except for the fact that the brake pedal is soft and not hard). Bleeding brakes (on each wheel) does not change anything. I tried two master cylinders. One original and one used (got from junkyard). Same problem with both. Both master cylinders were successfully bench bleed before installed. For more testing I also capped the master cylinder outlet brake line ports to see if the firmness of the brake pedal changed. Still the same problem. Brake pedal just sinks to the floor. Thanks very much for any help!
Jun 21, 2018 at 6:13 PM
