So, I changed the calipers on my car and bled the brakes by hand. One person pumping brake while I loosen and tighten the bleeder valve. After I did this pedal went to the floor. I started front tire brake reservoir side then next front then rear on res side than last farthest from res. Is it possible a big air bubble is trapped in there and I need to really pump even once fluid comes out? Thanks, please let me know if I need to explain better.
Oct 17, 2024 at 7:43 PM
