Using a scanner to automated the ABS I'm a little confused as to the procedure. First it says pump pedal repeatedly. Release pedal the pump pedal again. The pump motor starts running do you hold the pedal during this time or pump it like the scanner says. Then it says open left front bleeder and check fluid. Should the pedal be depressed at this time? It almost sounds like the bleeder should be open while the pump motor is running and the pedal is being pumped. It seems like all the fluid would be pumped out if this was the case. It then repeats for right front, left rear and right rear. The scanner is a Foxwell NT630+.
Nov 25, 2025 at 6:00 PM
