Original condition: Both Head light work, no front running lights, no turn front or rear turn signals. Left rear brake light only worked when pressing brake pedal and putting left turn signal on. Right rear brake light not working, no dash lights.
Work performed: New turn signal switch, new wiring to rear lights, new turn flasher, new bulbs, left front turn/driving socket replaced, left rear lamp replaced.
Current problem:
Left rear brake light only works with left indicator on.
No right brake light
No left front turn indicator
No left turn indicator in dash
No illumination in dash
Checked power coming out of turn signal switch and test light indicates that both left and right turn signals are getting power from switch.
When checking for power at left front turn lamp test light indicates no power.
I need help figuring out where to go next and cannot figure out if these problems are related or separate problems.
Current problem:
Feb 25, 2014 at 4:21 PM
