So, I have a couple things going on. First is recently after a road trip the brakes started dragging heavily. We got it home and did the brake fluid (came out black. I assume it's never been changed) the rubber line and calipers. Now sometimes when I press on the brakes, about halfway down it makes an audible pop that you can feel in the pedal, and it feels almost like it gives way or loses resistance for a split second. Sometimes it's loud and other times it's quiet.
The second issue is when I go over like a bumpy road slowly, there's this clunking almost popping sound and sounds like something is loose??? We've done practically the whole front end at this point. (Control arms, ball joints, sway bar end links, wheel bearings, tie rods, struts, and the strut bearings.) Everything is tightened to spec and I'm at a loss here.
Any help, questions, or tips would be helpful, thank you :3
Sep 23, 2024 at 1:23 PM
