When transmission is put into drive it will not forward without putting it in reverse and back into drive
2001 FORD MUSTANG
180,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
EDJOHNSTEIN
My car makes a winding sound and when places in drive will not move forward. I have to put it in reverse than drive for it to move forward. It is like the brakes lock up. I have had a slow leak but am unaware if it is the brake line or power steering.
Aug 22, 2018 at 7:22 PM
Good morning.
The noise may be from the transmission front pump starving for fluid.
Check your fluid level.
I would also suggest changing the fluid and filter in the transmission as well and see if the issue continues.
https://www.2carpros.com/articles/automatic-transmission-problems
Aug 23, 2018 at 2:58 AM
