Both high beams lights not working?
2006 CHEVROLET TRAILBLAZER
126,000 MILES • 6 CYL • 4WD • AUTOMATIC
JJV_119
Hi, my vehicle listed above EXT model, both high beam lights are not working. I checked the bulbs, fuse and relay and are appeared to be working.
What do you suggest I try next?
Thanks,
John
Nov 16, 2023 at 4:03 AM
There is a headlamp relay #43 we need to look at because it sounds like it is not working. Here is the location of the relay and I have included the headlight high beam and low beam wiring diagrams so you can see how the system works as well. Check out the images (below). Let us know how it goes.
Nov 16, 2023 at 11:03 AM
JJV_119
Thanks for the help the relay was the problem.
Nov 17, 2023 at 2:08 PM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Nov 17, 2023 at 5:08 PM
