Interesting. If they released when you opened the bleeder, then we know the calipers aren't the issue. Go all the way back to the master cylinder and do the same thing to see if they release. If they do, the problem is between the pedal and MC.
If that is the case, I suspect that when you installed the new master cylinder, the push rod wasn't aligned properly into the rear of the master cylinder. If the brakes drag even slightly, they will heat up. When that happens, brake fluid expands and will cause them to get tighter and tighter until they lock.
I attached a pic of the rod I'm referring to. Take a look through these directions for MC replacement. See if you did what is explained. I circled the part I'm referring to in the second pic. I have a feeling this is what is wrong. However, if you try the last test I suggested, we will know if it is between the pedal and MC. I can't think of anywhere other it could be, but better to check.
__________________________
2003 Dodge or Ram Truck RAM 1500 Truck 2WD V8-5.7L VIN D
All Except Hydroboost
Vehicle Brakes and Traction Control Hydraulic System Brake Master Cylinder Service and Repair Procedures Master Cylinder Removal and Installation All Except Hydroboost
ALL EXCEPT HYDROBOOST
REMOVAL - ALL EXCEPT HYDROBOOST
pic 1
1. Remove the brake lines from the master cylinder.
2. Disconnect the electrical connector for the low fluid level.
3. Remove the mounting nuts from the master cylinder.
4. Remove the master cylinder.
NOTE: Using care remove the master cylinder directly forward in order not to dislodge the output rod from its seat inside the booster.
INSTALLATION - ALL EXCEPT HYDROBOOST
NOTE: If master cylinder is replaced bleed cylinder before installation.
pic 2
NOTE: Make sure the output rod of the brake booster is in position before mounting of the master cylinder "This position will enable the output rod to enter inside of the master cylinder plunger sleeve during installation". Proper position is obtained when the output rod is centered perpendicular to the master cylinder mounting hole.
NOTE: Before installing the master cylinder, pump the brake pedal several times with the engine off to remove vacuum from the booster.
1. Install the master cylinder on the booster mounting studs.
2. Install new mounting nuts and tighten to 25 Nm (221 in. lbs.)
3. Install the brake lines and tighten to 19 Nm (170 in. lbs.)
4. Reconnect the electrical connector for the low fluid level switch.
5. Fill and bleed the base brake system.
______________________________
Feb 27, 2021 at 11:31 AM
(Merged)
