Yep sound like its in there pretty good
Only do what I'm about to tell you if you think its possible knowing what amount of debris has fallen inside if the debris pile is mostly towards the center this might work for you and most times there isn't as much as might be expected its uo to you if you want to try it or not
Many times this has been done without any risk of harming the engine
..but tread lightly ..
So if you didn't move the pistons much during this time
Then it might not need the head removed there's a way to get the debris out of the cylinder ..using a blow gun removes a lot
If you decide to try this . Here's a few alternatives.
you can suck it out with a small vacuum hose ..(compressed air activated vacuum)
Or " i usually just use a blow gun .
Also when you drill its a good idea to put thick grease on the drill and do it at a slower speed to catch all the chips in the grease before they fall inside clean the chips off and replace the grease as often as needed ..same goes for the extractor coat it with grease.. it also will require removing the cam to get all the valves closed first...
If you do use a blow gun try to get it pointing towards the cylinder wall so the chips move away from it and up and out the spark plug hole..
Most of them will come out in the first min of doing it ..and another a few mins for the rest you should have then all out in 5 mins but keep going till your sure you got them all
Another great tool is a video scope you can insert into the hole so you can inspect it to make sure there's nothing left in there
More times then not
I find that it will come out you'll get it ..
If you choose to try this before you start .. be sure the valves are all completely closed youl need to remove the cam so all the valves can close and then you can move the piston 2 inches below or so below tdc for more space in the chamber giving the blow gun more room to work out the small chips through the spark plug hole ...once done cleaning it out youl have to replace the cam and reset the valve timing of coarse
These procedures must be followed closely as to not damage anything during the process and
Keep in mind this is up to you
But this is way better than removing the head if you feel like you dont need to ..beacuse the only thing you remove is the cam to de activat the valves so they close and seal tightly so the particals have nowher to go but out the hole
The good part is the head intake manifold exhust header and pipes wires hoses gaskets Everything stays on
Ive had to use this method a few times over the years it always worked good for me didnt damage anything
If anything these are just good thought food that might help you diced what the next step is best of lck to you in deciding ..hope this helps
Aug 22, 2025 at 8:26 AM
