Welcome back: Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Do you mean the camshaft sensor or crankshaft position sensor? If it is the camshaft position sensor, you are at the wrong place on the engine. Behind the starter is the crankshaft position sensor. The camshaft position sensor on this vehicle is in the distributor.
Here are the directions for replacing the camshaft position sensor. The attached pictures correlate with the directions. Also, when you remove the distributor cap, make sure to make which spark plug wire goes to which tower on the distributor cap. They must be put back in the same place or ignition timing will not be correct. If possible, leave them connected and carefully move the distributor cap out of the way.
CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
1. Disconnect the negative battery cable.
2. Disconnect the spark plug wires and ignition coil wire from the distributor.
3. Disconnect the Camshaft Position (CMP) sensor harness connector from the distributor.
4. Remove the distributor cap screws.
5. Remove the distributor cap.
6. Remove the rotor screws.
7. Remove the rotor.
8. Align the square slot in the reluctor wheel with the CMP sensor.
9. Remove the CMP sensor fasteners.
10. Remove the CMP sensor.
INSTALLATION PROCEDURE
IMPORTANT: Do not use the old cap screws, CMP sensor screws, or rotor screws. Use replacement screws that have been coated with a thread locking compound. Precoated replacement distributor cap and CMP sensor screws can be acquired using P/N 10475922 (pkg of 10 screws). Precoated replacement rotor screws can be acquired using P/N 10475924 (pkg of 10 screws).
1. Align the square slot in the reluctor wheel with the CMP sensor.
2. Insert the CMP sensor through the reluctor wheel slot.
NOTE: Refer to Fastener Notice in Service Precautions.
3. Install new CMP sensor mounting screws.
Tighten
Tighten the screws to 1.6-2.8 N.m (14-25 lb in.).
IMPORTANT: The locating tabs on the rotor are necessary for correct alignment of the rotor. If the tabs are missing or damaged, replace the rotor.
4. Install the rotor onto the reluctor wheel.
5. Install new rotor screws.
Tighten
Tighten the screws to 1.5-2.4 N.m (13-22 lb in.).
6. Install the distributor cap.
7. Install new distributor cap screws.
Tighten
Tighten the screws to 1.8-3.0 N.m (16-26 lb in.).
8. Connect the CMP sensor harness connector.
9. Connect the spark plug wires and ignition coil wire.
10. Connect the negative battery cable.
Jul 15, 2019 at 9:48 PM
