Boiling hot Freon
1995 LINCOLN TOWN CAR
192,000 MILES • 4.6L • V8 • 2WD
DEMO1371
The A/C blows cold for a little bit then blows hot and the Freon in the unit gets really hot, boiling hot.
Jul 13, 2018 at 2:58 PM
Good evening.
The first thing you need to do is check the pressure in the Freon system to be sure there is sufficient pressure to activate the compressor.
If you do not have gauges, you can rent a set at a parts store.
When you command heat and cold, can you hear the blend door moving back and forth.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Jul 13, 2018 at 5:40 PM
