Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Lincoln
Town Car
Climate Control
Air Conditioner
Blows Hot
Boiling hot Freon
1995 LINCOLN TOWN CAR
192,000 MILES • 4.6L • V8 • 2WD
DEMO1371
MEMBER
1 POST
FOLLOW
The A/C blows cold for a little bit then blows hot and the Freon in the unit gets really hot, boiling hot.
Jul 13, 2018 at 2:58 PM
CERTIFIED EXPERT
Good evening.
The first thing you need to do is check the pressure in the Freon system to be sure there is sufficient pressure to activate the compressor.
If you do not have gauges, you can rent a set at a parts store.
When you command heat and cold, can you hear the blend door moving back and forth.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Jul 13, 2018 at 5:40 PM
