overheated the engine and now not starting
2000 HOLDEN UTE
230,000 MILES • 6 CYL • 2WD • AUTOMATIC
GORDS111
  • 10 POSTS
I was driving down highway when I boiled the motor. I pulled over and the engine stopped. I waited a while and then put water in. I picked up with trailer and now have it home. The motor cranks over but will not start. at times it kicks a bit but only a little bit, but does not start, but does appear to be cranking over nicely. definitely not seized. I have filled up water and currently have battery on charger as I flattened it trying to start.
Dec 29, 2016 at 4:19 PM
GORDS111
  • 10 POSTS
As an addition to above, battery now fully charged and cranking over beautifully. Engine firing regularly but not quite starting sort of like when no fuel.
Dec 30, 2016 at 4:24 PM
MHPAUTOS
  • 31,937 POSTS
I would be starting with a compression test, report the readings here for further assistance.
Dec 31, 2016 at 3:11 PM
GORDS111
  • 10 POSTS
how do I do a compression test
Dec 31, 2016 at 3:40 PM
MHPAUTOS
  • 31,937 POSTS
You need a compression tester that screws into the spark plug threads, crank the engine over and it will give you a compression reading, just make sure that the leads are away from the tester as you don't want a spark jumping and giving you a boot....you may be able to hire a tester if you can't get one from a friend, make sure it is one with a flex hose as you don't have a lot of room to get in, also what model Commodore is it?
Dec 31, 2016 at 3:48 PM
GORDS111
  • 10 POSTS
It is OK I just read that I need to get a compression guage, thanks
Dec 31, 2016 at 4:02 PM
GORDS111
  • 10 POSTS
thanks for your guidance it is a 2000 VS ute 6 cyl with about 230,00km
Dec 31, 2016 at 4:04 PM
MHPAUTOS
  • 31,937 POSTS
OK, comp test will tell us a lot about what is going on in the engine, if you get a comp that is very low compared to the others, squirt a small amount of engine oil into that cyl about a table spoon full and re test the comp, if it comes well up there will be a ring problem if not a gasket or valve problem will be causing the low compression.
Dec 31, 2016 at 4:21 PM
GORDS111
  • 10 POSTS
just bought a tester from super cheap. Do I just take out a plug and attach tester and then crank the engine and read the result
Dec 31, 2016 at 4:46 PM
GORDS111
  • 10 POSTS
should i do all cylinders
Dec 31, 2016 at 4:48 PM
GORDS111
  • 10 POSTS
have done all 6 cylinders readings follow
120
50 then with oil 65
3 others were 90
the last one i had terrible trouble getting unit attached which I think ieventually did
but reading appeared to be 0.
Sounds bad to me but then I really have no idea. What do you rthink
Dec 31, 2016 at 9:31 PM
MHPAUTOS
  • 31,937 POSTS
not good, 120 ok 3at 90 fair to poor 50 and with oil 65 will be valve problems or head gasket and 0 is a big worry try that one again and with some oil if nothing will probably be top end problems, but with the other poor readings, it will be a waste of time doing the heads as the bottom end is just about stuffed as well, may be time to look for a good second hand engine if you want to spend any money and keep the ute, trouble is a VS is worth not a lot these days and you have to weigh up the cost of re engine or scrap it, you will still be looking at 2-3k + to get a second hand engine fitted and do all the extras that will have to be done to ensure that nothing else goes wrong, may be worth getting a few quotes, where are you i may know some one you may be able to talk to first hand that you can trust.
Dec 31, 2016 at 9:47 PM
GORDS111
  • 10 POSTS
I am in Highland Park, near Nerang on Gold Coast Queensland
Dec 31, 2016 at 9:55 PM
STEVE W.
  • 15,113 POSTS
Yeah those numbers are very bad. A normal engine will run about 135 psi and up and you want all of the cylinders within 10% of each other. So the range for yours, using the 120 cylinder as "good" you would want to see no lower than 108.
Hate to say it but I think you need a replacement engine or IF the block and heads test OK you might be able to rebuild that one. Overheating most modern engines is a killer, they don't have the amount of metal in them like the old engines, thinner castings and aluminum to save weight make them easy to hurt.
Dec 31, 2016 at 9:56 PM
MHPAUTOS
  • 31,937 POSTS
i will ask a few mate if they know anyone on the gold coast, i am down in Vic myself.
Jan 1, 2017 at 12:06 AM
GORDS111
  • 10 POSTS
Thank you and happy new year you have made a bad situation bearable for me in which I have been able to see for myself what the actual problem is. 25 years ago I lived in Wodonga so just in Victoria
Jan 1, 2017 at 12:41 AM
MHPAUTOS
  • 31,937 POSTS
ok good luck with fixing the car.
Jan 1, 2017 at 2:30 AM
