If you drive the car slow with barely any gas but reasonable acceleration it won't bog down, but give it 25 percent on the gas or more the car shakes and shutters. if you floor it sometimes it will just bog out unless you are in the power band range 30 and 60 area you can floor it no problem just gaining speed. but I recently put in on the dyno and you can feel the transmission hard shift downshifting from 5th to 4th only have no misfires new computer dyno tuned went through 3 camshaft sensors to make sure. oil pressure sensor replaced wiring checked out fuel system checked. only thing I haven't checked is the transmission. I just wanted to know if my car will bog out not slip at all because of the transmission and you can't take off the line trying to race anybody.
Jun 10, 2021 at 7:45 PM
