body panel repair
2007 NISSAN ALTIMA
187 MILES • 2.5L • 4 CYL • 2WD • MANUAL
CMZANNN
  • 84 POSTS
Pulling up to bank i sideswiped a brick planter took the front fascia lower clean off.. i'm probably going to need some advice on repair. i felt like i barley tapped the brick planter. lower front clean off. i recovered whole thing.
Aug 7, 2020 at 5:26 PM
STEVE W.
  • 15,113 POSTS
They are not held on by much. Something like 8 screws and some push pins. You will want to look at the attaching points to see if any are torn or damaged. Sometimes you can use something like a fender washer if the screws pulled through the material.
Aug 7, 2020 at 8:57 PM
