Welcome to 2CarPros.
The body control module controls many things. Here is a list from my manual. Take a look through it and let me know if it helps. If there is a specific issue you are dealing with, let me know what it is and I'll try my best to help.
____________________-
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
- A/C compressor request.
- Remote Function Control.
- A/C cooling Fan.
- Audio Delay Power.
- Exterior and interior lighting control.
- Daytime running lights (DRL)
- Automatic lighting control
- Fog lamps
- Interior lighting.
- Battery rundown protection (Inadvertent Power).
- Chimes.
- Key-In-Ignition
- Head Lamps On
- Seat Belt Not Fastened
- Turn Signal On
- Park Brake Warning
- Door Ajar Warning
- Check gages
- Gage control.
- Instrument cluster indicator control.
- Theft deterrent.
- Engine coolant level sensing.
- Washer solvent level sensing.
- Key-in-ignition sensing.
- Seat belt use sensing.
- Brake fluid level sensing.
- Parking brake state sensing.
- Rear compartment interface.
- Horn interface.
- Door lock interface.
- Bulb Check.
Let me know if that helps.
Oct 30, 2019 at 7:21 PM
