Question regarding Body Control Module (BCM). Truck was killing batteries overnight, door locks and lighting acting weird. While probing fuse block (fuse removed) I found that the fuse socket for LBEC1 had voltage on both side (12.6/11.9) which may be normal but didn't make sense to me? Found the wiring diagram for LBEC1 and here's what I did/found: at key off and all downstream fuses removed socket read 12.6v/12mV. Flasher fuse in (12.6v/15mV), add door c/b (12.6v/1.5mV), add TBC 2a (12.6v/1.8mV), add TBC 2b (12.6v/1.5mV), add 2c (12.v/11.9v). Thought it might be drivers door module since I have had issues due to poor design, unplugging DDM (12.6v/11.9v). Pulled TBC IGN under hood 12.6v/11.9v). At key on voltage goes to 12.3v/5v. Pulled LBEC2 thinking it might be back feeding through DDM, no luck. Pulled BCM, had some corrosion on pins, cleaned up, reinstalled, passed diagnostics via OBD port. Only other codes are B0159-13 which I am trying to track down (new sensor did not fix), B1259-13 (xm radio antenna which I don't use, and despite the truck never having been in a collision two B0159-13 codes. Thinking the BCM is the culprit or is the strange voltage normal?
Aug 8, 2025 at 5:17 PM
