2000 BMW Z3 Re - Program Alarm Fob
2000 BMW Z3
MARK CLEVERLEY
  • 11 POSTS
2000 BMW Z3
I have an alarm fob that I think needs re-programming, I changed the battery with no effect. Can you tell how to re-program for a BMW Z3.
Regards
Mark Cleverley
Jul 4, 2009 at 4:29 AM
DOCHAGERTY
  • 9,603 POSTS
Is it built into the key?
Jul 4, 2009 at 11:54 PM
MARK CLEVERLEY
  • 11 POSTS
Yes it is built in to the key.
Regards
Mark Cleverley
Jul 5, 2009 at 1:50 AM
DOCHAGERTY
  • 9,603 POSTS
To reinitialize your key(s) after a battery replacement or some other reason, get in the car and shut the door. Insert the key into the ignition and turn to the ignition on position, but don't start the engine. Then remove the key and hold the "lock" button down whilst pressing the unlock button 3 times. Then the doors should lock and then un-lock. Repeat the process with any additional keys (if any) Opening the door or starting the engine takes the car out of the programming mode.
Jul 5, 2009 at 10:19 AM
MARK CLEVERLEY
  • 11 POSTS
Your advice did not work. I am not sure if I have mis guided you when I saif the key is part of the fob. Just to confirm that it is. The fob has one large button with the word LOCK, and 2 smaller buttons behind it (one will be to unlock, whilst the second one is for the interior light), the key part then comes out of the fob.
Regards
Mark Cleverley
Jul 5, 2009 at 11:09 AM
DOCHAGERTY
  • 9,603 POSTS
Got it Mark, there is another procedure for the E-36 cars and I will get that to you in a bit, I have to access my own computer.
Jul 5, 2009 at 11:19 AM
MARK CLEVERLEY
  • 11 POSTS
Hi Dr Haggerty did you manage to get the other procedure for programming alarm as you indicated.
Thank you in advance
Mark Cleverley
Jul 6, 2009 at 6:02 PM
DOCHAGERTY
  • 9,603 POSTS
Having some technical issues, be there tonight.
Jul 8, 2009 at 4:29 AM
MARK CLEVERLEY
  • 11 POSTS
Dr Hagerty did you manage to sort out your technical issues , as I still await info to my problem.
Regards
Mark Cleverley
Jul 9, 2009 at 1:59 AM
MARK CLEVERLEY
  • 11 POSTS
Dr Hagerty sorry for being a nuisance but any information?
Best Regards
Mark Cleverley
Jul 10, 2009 at 6:27 AM
MARK CLEVERLEY
  • 11 POSTS
Dear Dr Hagerty,
Please let me know if you can or cannot help me, so I do not feel ignored or I can stop pestering you.
Regards
Mark Cleverley
Jul 12, 2009 at 3:06 PM
DOCHAGERTY
  • 9,603 POSTS
Mark, I am sorry for the delay. I will get your answer today at work.
Jul 15, 2009 at 8:15 AM
MARK CLEVERLEY
  • 11 POSTS
Dear Dr Hagerty can you help please? I posted my problem on the forum because I was not getting any answers, it appeared for 1 day then disappeared why? I did make a donation albeit a small one.
Regards
Mark Cleverley
Jul 18, 2009 at 6:35 AM
MARK CLEVERLEY
  • 11 POSTS
Have you purposely ignored helping with my request?
Jul 25, 2009 at 11:51 AM
DOCHAGERTY
  • 9,603 POSTS
Can I have the last 7 digits of the vehicle ID number. I have started a search and it is model ID dependent.
Jul 25, 2009 at 7:31 PM
MARK CLEVERLEY
  • 11 POSTS
Dear Sir,
As requested here are the last 7 digits of the vehicle ID.
LG24671
Regards
MArk Cleverley
Jul 26, 2009 at 8:02 AM
MARK CLEVERLEY
  • 11 POSTS
Dear sir, do I take it that you have given up on my problem? I do what you ask me to do but you seem to not want to respond? Why?
Regards
Mark Cleverley
Aug 5, 2009 at 3:10 AM
DOCHAGERTY
  • 9,603 POSTS
PREPARATION
1. Close all doors, trunk, and hood
2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot.
ENTER CODE LEARNING MODE
3. Open trunk and leave it opened.
4. Open the drivers door and sit in the drivers seat.
5. Close the drivers door.
6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated.
Do No start the engine.
The Ignition switch cycling in step #6 must be performed within 10 seconds.
The sequence in steps #1-#6 must be performed within 45 seconds.
REGISTER/DELETE ID CODE(S)
7. Open drivers door, (remain seated in the drivers seat)
8. Close the drivers door.
9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered.
10. Repeat steps 7 thru 9 to register the three ID codes.
It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory.
EXITING CODE - LEARNING MODE:
11. Open drivers door, and exit from the vehicle, leaving the door opened.
12. Close trunk.
13. Close drivers door. The LED will turn off and the siren will 'chirp twice.
14. The initialization procedure is now completed; Test all remotes to confirm operation.
User avatar
Aug 8, 2009 at 11:03 AM
