Air cond system has 3 fuses. One, the smallest 7.5, has blown twice. What might be the cause of this and what is the next step to take?
Aug 10, 2009 at 1:13 PM
DOCHAGERTY
CERTIFIED EXPERT
What number fuse is blowing?
Aug 17, 2009 at 8:27 PM
STEVENH21
MEMBER
#39. Goes to the compressor relay. Relay has continuity on the control circuit. Can't really test to see if switch is closing. Guessing either bad relay or compressor drawing too much power. Fuse blows from 3 blocks to 1/2 mile with air on, then air cond. stops.
Aug 17, 2009 at 9:27 PM
DOCHAGERTY
CERTIFIED EXPERT
I will get the wiring diagrams and we will get it fixed, I will repost in the morning mate. ♥
Aug 17, 2009 at 10:01 PM
DOCHAGERTY
CERTIFIED EXPERT
You called it right, the only thing on that circuit is the compressor control relay and your guess of the mag clutch or the relay itself being the culprit is quite possible mate. Run some current draw tests and see what the magnetic clutch is pulling.
