1997 BMW Z3 cat converter
1997 BMW Z3
110,000 MILES • 4 CYL • 2WD • MANUAL
DEEP13SEA
  • 4 POSTS
My o2 sensors and cat converter bad , had diagnostic done but not the specific to isolate o2 sensor or cat converter. My question I just dont have the money right now for a cat converter or sensors, what course can I do just to make car runnable to get back and forth to work?
Jul 20, 2009 at 9:22 PM
Honestly, a clogged catylatic converter can cause other problems that will cost you. The O2 sensor you may get away with, but the fuel economy may drop as well as the engine's performance. If you disconnect the catylatic converter and put a straight pipe in its place, that would eliminate blockage, but its against the law.
My recommendation is to try to get the money to fix it correctly.
Jul 20, 2009 at 9:36 PM
DOCHAGERTY
  • 9,603 POSTS
The amount of $ in your budget should be enough to cover replacement of both, there are several good aftermarket suppliers of direct replacement parts that are reasonable, and I too believe the repairs should be done correctly, no "test pipes".
Jul 21, 2009 at 7:50 PM
