1997 BMW Z3 access to the in tank fuel pump
1997 BMW Z3
GTXJOHNNY
Engine Performance problem
1997 BMW Z3 4 cyl Two Wheel Drive Automatic 100.00 miles
I am trying to install a new fuel pump, How can I access the old one in the tank?
Sep 21, 2010 at 2:21 PM
DOCHAGERTY
  • 9,603 POSTS
First, draw out all the fuel you can. If you dont, you will spill fuel into the car. Remove the passenger seat. Access to the tank is found by cutting the carpet at a perforation that starts from about three inches up from the floor, runs in a circle to about a foot up from the floor. The sheet metal cover comes off after the fuel and electrical connectors are released and then the tank is in view. There is a large plastic screw cover that requires a special tool to remove, two large flat screw drivers crossed and used to span the screw cover at the ridges, and then carefully turned will do it. Then you are in, and if you did not drain the tank, you will have found out why you should have at this point.
Sep 22, 2010 at 10:15 AM
