Fault codes
2008 BMW X6
125,123 MILES • V6 • AWD • AUTOMATIC
MB-POWER
  • 80 POSTS
check engine light is on , scanned and found following codes :
2ABE : charging pressure sensor 2 , electrical.
3100 : charging pressure control, switch-off.
tried to clear those codes but they come back!
any advice and help?
Thanks
Oct 5, 2017 at 1:35 AM
It sounds like the alternator is out and needs replacement.
Here are a couple of guides to help confirm the problem so you can get it fixed:
This will give you an idea of what you are in for when changing the unit.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Clear the codes once you are done.
https://www.2carpros.com/articles/check-engine-light-clear-codes
Please let us know what you find.
Oct 6, 2017 at 12:01 PM
MB-POWER
  • 80 POSTS
I think this problem belong to turbo charging pressure or catalytic converter system.
thanks
Oct 7, 2017 at 4:31 AM
MB-POWER
  • 80 POSTS
throttle body & turbo pipe has been cleaned and every thing is okay now.
thanks
Oct 8, 2017 at 8:58 AM
Sorry didn't know it was a turbo. DOH
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 9, 2017 at 10:14 AM
