2004 BMW X5 Angel Light Fuse
2004 BMW X5
160,000 MILES • V8 • AWD • AUTOMATIC
AKBMW
What fuse is associated with angel lights and side lights? It is not listed in the fuse chart.
Jun 27, 2010 at 12:27 PM
DOCHAGERTY
  • 9,603 POSTS
There are two fuse boxes on that car. One in the trunk area and one in the glovebox. Are you sure it's a fuse?
Jun 27, 2010 at 3:00 PM
AKBMW
Since both angel lights and both side lights are not illuminated and I get a message on the dash to check the side lights. I believe that all these lights went out at the same time as the car was serviced recently, this is why I believe that a common link is a fuse.
The fuse chart in the glove box is not clear in identifying side light nor angel light.
Jun 27, 2010 at 9:04 PM
DOCHAGERTY
  • 9,603 POSTS
Fuses by Application
10/03 -
ABS, ASC, DSC 12,51,55,63
Additional socket in luggage compartment 83
Adjustment driver seat 26,32
Adjustment passenger seat 21
Airbag a. Side airbag 44
Air conditioner 34,48
Air suspension 57,79,87
Automatic choke 16
Auxiliary heater diesel 59
Blower 34,64
Brake light 9
CD changer 75
Central locking system 20,24,60
Central locking system rear lid 84
Central locking system remote control 86
Centre console switch panel 32,37,53
Cigarette lighter (socket) 25 (33 AUS)
Courtesy mirror illumination 42
Diagnostic plug 52
Electric seat heating 32,53
Electrics box fan 51
Engine control 5,31,54
Fuel pump 47
Garage door opener 33
Glove box light 27
Hand lamp 36
Headlight cleaning 28
Heated rear window 34,85
Heated spray nozzles 34,48
Heated steering wheel 29
Horn 10
Immobilizer 11,16,39
Independent heater 59
Instrument cluster 1,43,45
Inside mirror electrochromatic 6
Light module 2,9,61
Navigation 7,73,75
On-board computer 7
On-board Diagnose II 14,51
On-board monitor 7,73,75
Outside mirror 6,17,20,24,60
Parking aid 6
Passenger compartment/trunk lighting 17,27
Radio 7,72,73
Rain sensor 41
Rear blower 3
Rear seat back adjustment 77
Rear seat heating 4,80
Rear washer 81
Rear washer pump 81
Rear window washer 41
Secondary air pump 51,62
Servotronic 14
Shifting gate illumination 8,12
Sliding/tilt roof 58
Speed control 9,39
Starter interlock 39
Steering column adjustment 23,26
Telephone 7,73,74
Thiefproofing system 6,13
Trailer socket 78
Transfer box 46
Tyre pressure control system 6,15
Window lift front 20,24
Window lift rear 60
Windscreen washer system 27
Windscreen wiper 40
Jun 27, 2010 at 9:23 PM
DOCHAGERTY
  • 9,603 POSTS
The lighting module fuses are possibly where to go, or the bulbs. Or the general module is questionable.
Jun 27, 2010 at 9:29 PM
