2002 BMW X5 lowbeam headlights..shut off after 5 to 10 sec.
2002 BMW X5
120,000 MILES • 6 CYL • AWD • AUTOMATIC
JUSTJR
My lowbeam lights will not come on. Intermitantly, they with come on for a few seconds and then go off with a "message"...check lowbeam lights. The bulbs are good. The switch is good. It could be a bad relay??? I can't find the relay! to check it. I have the "auto-on" switch on the dash. The lights will not come on in manual or auto. Hi-beams are ok. Fog lights ok. Problem occured after about two weeks of not driving and the bat ran down. Recharged fine...but lowbeam headlights would not work. Thanks
Dec 29, 2007 at 11:10 AM
DOCHAGERTY
  • 9,603 POSTS
Prepare for some bad news. Try this first, disconnect the battery for a minute and then reconnect it. This is what BMW calls a master battery reset, its like control, alt, delete on your computer. If that does nothing, you will need to scan for fault codes and/or "reflash" the general module. You may have fried something during the battery recharging session.
Dec 29, 2007 at 8:27 PM
