i have a 3.0i x5 which has recently had a constant audible tone inside the cab, this tone is audible from the moment the door is opened on the vehicle (before entry & before the key is in the ignition). the tone sounds very similar if not the same to the sound that is heard from the pdc when parked too close to another vehicle. also when the pdc button is pressed there is another audible tone for a few seconds and the green led continually flashes. I suspect there is a fault with 1 of the sensors, but am unsure if this is also the cause of the other continuous audible tone. Please can you help.
Jan 24, 2009 at 5:37 AM
