I recently had a check engine light come up checked the code and the car was running perfect .except for a faulty 02 sensor for bank 1 sensor two. I replaced the wrong sensor the left rear instead of the right rear after I realized I change the wrong side I put the sensor I took out of the good side the sensor which was old and put it where the code was bank one sensor two no more check engine light but the idle is now rough and a vibration is occuring is it possible the old sensor from the good side is also bad? there is no more code?? No. Check engine light ??
Oct 5, 2009 at 1:10 AM
