Cranks but will not start
2001 BMW X5
GREASEMONKEY40
The X5 will crank and will not start and no codes.
I have replaced the fuel pump and fuel filter and the crank sensor.
When it was cold out it would start just fine but when it started to get warm it started to act up and now it is hot it will not start at all.
Jun 24, 2009 at 9:52 PM
DOCHAGERTY
  • 9,603 POSTS
It is difficult to advise you here as I do not know the history of the car. At any rate, it will at least require spark, fuel, etc. Probably a coil, have you tried that?
Jun 24, 2009 at 10:30 PM
GREASEMONKEY40
I have checked and i have spark and fuel and still no start. i have had it at BMW Of Dallas and thay don't know what it is. could it be the computer.. the computer has been reprogramed.
Jun 24, 2009 at 10:52 PM
MURPHY29
Im having the same problem with mine did you discover what was causing yours...
Oct 3, 2009 at 6:34 PM
DOCHAGERTY
  • 9,603 POSTS
A crank, no start condition in that model can be caused by several things, bad fuel or no fuel pressure, no spark, disconnected air mass sensor, failed cam or crankshaft sensors, poor compression. I have seen bad instrument clusters cause a no start condition. Lets roll up our sleeves and fix it mate!
Oct 4, 2009 at 11:38 AM
MURPHY29
In that case would you recomment I go to a main dealer to get a computer dianostic done.
Oct 4, 2009 at 5:11 PM
DOCHAGERTY
  • 9,603 POSTS
That would be one way. As a technician who has been at the dealer level long enough to make it to master level, I resist recommending that route as it usually is much more expensive and the quality of work tends to suffer. I recommend seeking an independent BMW mechanic that has a reputation for delivering rather than risking the clumsiness of some rookie at the dealer.
Oct 4, 2009 at 9:39 PM
PETE1982
Dis you happen fix your car yet?? Because im having a problem with my car, same problem.
Jun 24, 2019 at 5:53 PM
Can I ask if you hear the fuel pump run in the tank when the key is turned on without cranking the engine over? Do you have a check engine light? if so any codes? These two guides should help.
and
Please run down these guides and diagrams and report back.
Jun 24, 2019 at 6:18 PM
