Better to refurbish or buy new engine..help!!!!
2001 BMW X5
VIDADIGI
Engine Mechanical problem
2001 BMW X5 6 cyl Automatic 97000 miles
I really need help!! I own a 2001 bmw x5..after spending 1300 @ dealership.. problem still not fixed and they say the engine has a block??? I am a single mother and know NOTHING of cars. Bottom point is.. I have no car and need a suggestion on what is cheaper getting a used engine or refurbishing the current one. My budget is low...also.. where can i get my engine refurbished in RI??
Feb 27, 2009 at 8:33 PM
This depends on a lot of variables. First here is a video that will help with how an engine works.
https://youtu.be/FcRyFHPZNQo
This is important to help understand how it works because depending on what has failed will determine the extent of the rebuild. If you have to completely rebuild the engine all the way down to the piston rings and conditioning the bores, then I would suggest finding a replacement engine.
The reason is labor costs these days is much higher than it used to be and so in a lot of cases it is cheaper to replace the engine. Plus, most replacement engines comes with a warranty.
However, if you just need to replace a head or maybe crank bearings then it will make sense to rebuild it. This is why it is critical to know what is needed for the rebuild. Most people these days use the term rebuild even though they are not dissembling the entire engine and rebuilding it, so it gets confusing.
Here is another video on a completely different engine that shows what I am referring too. Basically, if you have to remove the pistons, then I would just replace it.
https://youtu.be/ola8SuIx8S4
The last factor that really matters is the actual labor cost per hour. This is what is going to cause the rebuild cost to be higher. So, if they are over $100 per hour then I would just replace it.
Please run through this and let us know what questions you have. Thanks
Nov 11, 2021 at 7:28 AM
