ABS and DSC lights come on
2001 BMW X5
BRYE
Drive Train Axles Bearings problem 6 cyl Four Wheel Drive Automatic 67000 miles
I have x5 2001 3.0. when I start the engine, and the car is moving, the first thing I apply the brake I hear the metal grinning noise and shaking a little, then the ABS and DSC lights come on then the car is driving fine. I don't know what the problem. Please help me.
Feb 20, 2009 at 7:57 AM
Where is the noise coming from? it sounds like you have a wheel bearing hub going out which will cause the ABS and DSC light to come on. Here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/bearing-hub-replacement
Also here is a video that will show you how to get the codes so we can see which side it is
https://youtu.be/rTtAnsOlZU4
Please let us know what you find.
Feb 20, 2009 at 11:27 AM
BRYE
noise is from the right side. i guess that's common. but what i'm'worried is my ABS, DSC and Hand Brakes lights comes out. its like when i release my hand brake it turns to yellow light. but still the lights with ABS and DSC is still on.
THANKS APPRECIATE
Feb 20, 2009 at 11:48 AM
It still sounds like an axle hub bearing that is out, can you lift the car on the right and see if there is play in the wheel?
Here is a guide.
Please run this test and get back to us.
Feb 20, 2009 at 1:07 PM
BRYE
Yep the wheel had so much play I cant believe it. I had the repair done at a shop it cost me $340.00. ABS and DSC lights all off everything working good, Thanks for the tip this site is great.
Feb 21, 2009 at 12:50 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Mar 4, 2009 at 6:26 PM
