I need to access the Left C-pillar area to install a bluetooth antenna. Any one know where I can instructions on panel removal and reinstallation?
Aug 19, 2009 at 9:11 AM
DOCHAGERTY
CERTIFIED EXPERT
As I read your question, the "C" pillar finsher removal procedure is quite straightforward. There seems to be a plastic cover that can be popped off that has a Torx screw behind it and then you can pop the plastic anchors loose with a firm tug.
