Engine Mechanical problem
2004 BMW X3 Front Wheel Drive Automatic 105000 miles
My 2004 X3 2.5i has an oil leak. It is small. I lost about two quarts of oil between oil changes (3500 miles of driving). After getting it checked out it appears that I have several leak points. One is from the oil pan gasket and the other(s) are from the engine but I don't know where exactly. My mechanic says it's safe to drive as long as I top of the oil once a week.
What do you think I should do? I am torn between trading it in (I am not sure how much I will get for it even without the oil leak) and getting it fixed which will cost $2000+ because of the labor involved to remove the engine and diagnosis and fix the leaks.
What is your suggestion/recommendations?
Jun 18, 2010 at 5:16 PM
