Engine will not crank
2007 BMW X3
200,000 MILES • 4WD
YFNTIDO
Would a code need to be removed for my car to crank back up after new parts were replaced??
May 31, 2021 at 6:33 PM
STEVE W.
  • 15,113 POSTS
That would depend on the code and the parts replaced. Some pieces need to be programmed in and some don't. Some codes will prevent a vehicle from running until the fault is repaired and the code cleared. What is the code and parts that were replaced?
May 31, 2021 at 6:50 PM
YFNTIDO
Starter and crank shaft sensor, don’t know the exact code the guy just said he needed a stronger machine to clear whatever because it won’t start until then. what do you think ??
Jun 1, 2021 at 3:48 AM
STEVE W.
  • 15,113 POSTS
For the crank sensor it can set a code that needs more than just a code reader to reset so it's possible. It's also possible that while changing the starter and having the battery disconnected it activated the anti-theft and now that needs to be reset which also takes more than a simple code reader.
Jun 1, 2021 at 10:36 AM
YFNTIDO
Wow, okay. Thanks
Jun 1, 2021 at 12:58 PM
STEVE W.
  • 15,113 POSTS
You're welcome. Thank you for using 2CarPros
Jun 1, 2021 at 5:32 PM
Jun 1, 2021 at 7:15 PM
