I need your help. A Code 120308 Low pressure code comes on Transmission malfunction light comes if I drive over 80 kms/hour, lower speed car is running smooth at 40-60 kms/hour. Vacuum pump, boost solenoid switch replaced. Could a diverter valve replacement be required? Before I had lean fuel code which was corrected by installing new turbo intake pipe.
Pl. suggest.
Thanks,
Ashok Toronto
Car listed above has turbo.
Pl. suggest.
Thanks,
Ashok Toronto
Jun 8, 2022 at 4:41 PM
