2000 Other BMW Models Air filter change. Circular type.
2000 BMW
33,000 MILES • 4 CYL • FWD • MANUAL
LEONARD WEBSTER
MEMBER
FOLLOW
How do I change a circular airfilter on my BMW 318i?
Nov 3, 2009 at 12:43 PM
DOCHAGERTY
CERTIFIED EXPERT
BMW uses a rectangular air filter on their cars, unless it is an aftermarket type or you are referring to the oil filter. If it is an aftermarket type, just follow the manufacturers recommendations.
Nov 3, 2009 at 10:56 PM
LEONARD WEBSTER
MEMBER
Dear Dr Hagerty mine is the circular and is situated on the right hand side of the eng compartment.
You must be a Scot with a name like Hagerty?
Nov 4, 2009 at 3:06 AM
DOCHAGERTY
CERTIFIED EXPERT
Irish, not Scotch. Thanks just the same. Please send the last 7 characters of the vehicle identification number, it will allow me to access the database and send the correct information.
Nov 4, 2009 at 8:17 AM
LEONARD WEBSTER
MEMBER
ID No. WBAAY72070KJ75334
I could tell you are not a Scot as you spelt it Scotch.
Scotch is brewed in Scotland and Ireland as you know. Regards.
Nov 4, 2009 at 8:45 AM
DOCHAGERTY
CERTIFIED EXPERT
The 316 with the N42 motor never made it to the US market. Loosen the clamp at the throttle body, then pull the vacuum hose from the intake boot and after the mount screws are removed, out it comes. And then you can service/replace the air filter/silencer.
