1985 Other BMW Models cooling
1985 BMW
NICHOXLAS
  • 6 POSTS
Engine Cooling problem
1985 Other BMW Models 6 cyl Wheel Drive Type unknown Automatic 140 miles
My 635 csi bmw drives for about 20 minutes, but then over heats and shoots all the coolant out of the reservoir. i just changed the thermostat and the water pump isnt too old. what else could it be?
Mar 27, 2008 at 4:31 PM
Try bleeding the cooling system don't work do the tests below.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Mar 27, 2008 at 6:07 PM
