A few months ago, I notice a very light jerking, here and there though it did not impact the drivability. The car consumes quite a bit of oil, so I usually have to add a quart here and there.
About a week ago, I noticed the vehicle shaking while it started- a day later, the check engine light came on and it started rattling excessively.
Multiple codes came on, that included:
Cylinder 7 Misfire
Cylinder 4 Misfire
Cylinder 6 Misfire
Cylinder 5 Misfire (multiple)
Cylinder 3 Misfire
Exhaust Camshaft Timing Over-Retarded (Bank 2) – P0300
Cold Start ‘’B’’ Camshaft Position Timing Performance Bank 2 – P05CF
Glow Plug Control Module Circuit Range/Performance – P13B7
Transmission System Fault – P176B
Battery Voltage is below normal (11.3 V).
So far what’s been done – all the spark plugs, and ignition coils were replaced (approx. 2 months ago).
Also, replaced the PVC values (Breather hoses, connecting lines on both sides).
Not sure what is going on at this point. Please help!
Cylinder 7 Misfire
Cylinder 4 Misfire
Cylinder 6 Misfire
Cylinder 3 Misfire
Feb 12, 2025 at 9:09 PM
