2001 BMW M3 Battery drain
2001 BMW M3
51,000 MILES • 6 CYL • 2WD • MANUAL
RJAMROZ
Upgraded sat nav computer from mk3 to mk4 and also upgraded to a widescreen display. On the fuse panel it indicates under navigation that in position 7 needs a 5 amp fuse and position 41 a 30 amp fuse. Originally there was no 30 amp fuse when i had the mk3 computer so i put in the 30 amp. Since then the computer sometimes dosnt work (but this is rectified by merely pulling out the 30 amp fuse and putting it straight back in) and the battery keeps going flat. Any suggestions?
Jul 21, 2009 at 5:05 PM
You probably have a short circuit somewhere within the electrical system that's draining the battery-Try the battery drain test below.
https://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_113.jpg
Jul 21, 2009 at 5:29 PM
