1995 BMW M3 Nothing works since service!
1995 BMW M3
66,000 MILES • 6 CYL • 4WD • MANUAL
FLALLEYCAT
Just spent about $6,000 to have my baby undergo some plastic surgery as well as 65000-mi physical. I had the driver's side door panel replaced as it was separated from door frame. Other work was on tires, engine, shimming taken care of, routine stuff.
Since getting car back, the driver's seat's automatic adjustments won't work, neither windows nor sunroof will open, and all sorts of alarm lights stay on after car has been running a bit. First, airbag light stayed on; now it doesn't stay on as long, but the break-fluid light is constantly on even tho break fluid is fine; now break pad light comes on and break fluid light is off.
Could all these problems possibly have occurred from just having door panel replaced? Of course, I'm going to contact the dealer re these problems but wanted a little bit of knowledge before talking with them. The only thing electrical I can figure out they came near was the door panel replacement.
Thanks for replies and assistance!
Allie
May 21, 2008 at 10:16 AM
DOCHAGERTY
  • 9,603 POSTS
Would it be possible to see the repair billing? $6k is a fair amount of work to be done on most any car. If the work was sub-standard, it will require an inspection of the paperwork not to mention the car itself in order to determine where the issue is.
May 22, 2008 at 7:59 AM
