I have aftermarket DEPO headlights with angel-eyes wired into the flashers, bought the car 6 months ago as is and everything was fine with the lights. I replaced the flasher bulbs with "stealth" lights and realized one of the sockets was 150 deg. and the other 180 and that two 180 bulbs had been installed, one shoved into the 150 socket (have now replaced with 2x 180's). After changing the bulbs, when I turned on the headlights (even to the running position) the flashers are "frozen" on and do not blink causing me to drive with no working turn signals in the dark. I was thinking it was the relay but when the lights are off the flashers work fine so I don't want to buy the relay if it's more likely a ground issue but all the wiring seems legit (a little shoddy but it all seems right and worked fine before)
Jun 1, 2009 at 12:33 PM
