Good day, I recently changed my transmission oil, filter as well as the center bearing and coupling on the propshaft due to vibration. The problem I have now is that the car does not want to change past second gear. It will have a high rpm of up to 4,000 RPM's then it will change to third, as soon as it goes to third the car goes into limp mode. Can't drive the car over 45 kph at the moment. Also when I swift the car into drive from park it feels like the car is kicking into first gear. It knocks when I put it neutral. Any idea what it is? Thank you
BMW e46 318i
BMW e46 318i
Nov 16, 2019 at 6:01 AM
