Engine was missing and while testing for spark using a grounded test light, without inserting the spark plug into the coil, I cranked the engine. The ignition fuse (30A) was blown. After replacing the fuse car cranks but no start. All six connectors of the wire harnesses, there is 12v at the power (red) wire. Ground (black) looks okay. The third wire color is different on all six harnesses.
Before suspecting the crank position sensor I want to make sure the coils are good.
The connector socket on the tip of the coil has the triangular shape with 3 pins. After identifying the pins with the corresponding wires did the bench test. I gave 12 v to the power pin and grounding the top pin of the coil, tried to trigger the coil with the powered test light but to no avail.
Is there any method to bench test the COP?
There is fuel.
Have I damaged the coils while testing for spark? I understand the transistor is inside the coil.
The crank sensor was a cheap one that I installed couple of months ago.
Please advise.
There is fuel.
Please advise.
Jul 24, 2020 at 7:01 AM
