My BMW 840 is in "limp mode" with the "trans fail-safe program message reading in the display on the dashboard. The diagnostic computer codes come back as 00120 - undocumented code
106 - stall manitoring
100 gear monitoring 2nd - 4th gear
40 brake light switch/pedal travel
00036 undocumented code
50 fuel line switchover valve circuit
6 wheel speed signal front rigt
7 wheel speed signal front left
Stays in limp mode 3rd gear (Actually in drives in 3rd, 4th and 5th gear at this time.) Repair not (not BMW) says new transmission. Can you comment/interpret these codes. I'm thinking speed sensor or battery problem or voltage problem. Please response. Repair shop wants to charge me over $6000 to put in a new transmission. Somehow I'm thinking not necessary when the car drives. Please respond. Thank you for your time and attention.
Aug 19, 2008 at 7:02 PM
