1989 BMW 750Li Change battery
1989 BMW 750LI
150,000 MILES • V12 • 2WD • AUTOMATIC
COLLEGE
I have a 1989 BMW IL and I know the battery is under the rear passanger seat. How do I remove the seat. I have tryed to lift it but no luck. Can you help me?
Aug 20, 2008 at 11:04 AM
DOCHAGERTY
  • 9,603 POSTS
The right rear seat needs to come out. First raise the seat as high as it will go and look under the seat for a rod that is hooked into a space in the "tub" of the car and on the other end is a 17mm bolt head. Unscrew the bolt and the seat base will come out. Replace the battery and then the seat base.
Aug 20, 2008 at 9:07 PM
