This is regarding the car listed above 745LI. I have recently changed coolant thermostat, upper and lower coolant sensor and radiator fan. I keep on getting Engine overheated at 107C. The Water pump is working fine as I can see a steady stream of coolant in coolant reservoir. The coolant is between Min and Max range (no coolant leak).
Upper radiator hose is hot and lower radiator hose is warm to touch.
I am able to drive for 30 minutes continuously and the message keeps on popping and disappears and this cycle continues.
Also the radiator fan does not come on when the overheating message pops up. Only when I start the A/C, the fan starts.
Any help is demystifying this issue is much appreciated.
Thank you.
Thank you.
Nov 17, 2020 at 10:55 AM
