What is it leaking? (oil, coolant, fluild..) Where is it leaking at? (under hood, exhaust etc..). When does it leak and how badly? (only while driving, when idling, etc..)
Jun 24, 2009 at 7:08 PM
KELEESH
MEMBER
it looks like its leaking behind the water pump out of a small hole on the block {coolant}
Jun 24, 2009 at 7:48 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Are you sure it isn't the waterpump itself leaking? It can leak causing it to appear to be leaking from the block..they will leak when they begin to fail
Jun 24, 2009 at 9:16 PM
KELEESH
MEMBER
COULD BE! I JUST WANTA MAKE SURE I CAN SEE THE HOLE IN THE BLOCK I DONT KNOW IF ITS SPOSE TO BE PLUGGED OR NOT!
Jun 24, 2009 at 9:53 PM
DOCHAGERTY
CERTIFIED EXPERT
The work is extensive. It is an O-ring failure. 16 hours labor. Will you do it yourself?
