2001 BMW 740 rough idiling
2001 BMW 740
NATBMW
Engine Performance problem
2001 BMW 740 V8
I have a 2001 740i. The car was running great then all of a sudden it started idiling rough and it was hesitant. Do you have any idea what the problem could be?
Apr 26, 2009 at 3:34 PM
DOCHAGERTY
  • 9,603 POSTS
The problem you might be having is possibly related to the PCV plate on the back of the manifold. At some time in the life of all the M-62 motors, they require it to be replaced. When they fail they show symptoms that you report. Go to Realoem.com and look for part# 11-61-7-501-563. The plate can be removed from the car without pulling the manifold, but be careful not to strip the heads on the T-30 Torx screws or you will be removing the entire manifold. Also replace the throttle plate profile gasket as well. Has the valley pan ever been replaced?
Apr 27, 2009 at 7:43 AM
